Please I need ok would like the “Process” indicator to be more conspicuous and as with other Topaz software down the bottom of the screen
Thanks for your feedback.
We’ve moved the indicator to the image settings panel to keep the location of all the settings consistent as well as make space for a coming UI change in the bottom left corner.
How would you prefer it to be more conspicuous? Larger? A sound notification? An animation?
My problem was that De-noise and Sharpen Ai are near the bottom of the screen then Photo Ai is at the top, if you’re using all the pieces of software it is better if they’re all in the same location, however both being slightly larger and a sound notification would be helpful.
Thank you for your speedy response!
