Topaz AI position on screen
The AI page is not centered on my monitor. I cannot see the R. hand edge completely. This is annoying and can prevent me from seeing what AI is doing. If you have the power to correct this problem, please do so immediately!
This sounds like a Window configuration conflict. Can you drag the application around your screen or minimizing/maximizing it? Are you able to close the app and reboot your computer?
