Topaz AI & HDR's
I’m wanting to use Topaz AI on an HDR file. The file loads fine & the process is as with any other file. The only export option it seems that retains the HDR aspects is DNC. It begins the process then fails. This a bug or am I missing a step?
Please take a screen recording of this behavior so I can see exactly what is happening.
Loom is a great free application for this: Loom | Free Screen & Video Recording
Not sure if a recording would help much but, here’s a screen shot the error message:
Mark
  1. The original image file.
  2. The processed image.
Dropbox File Request
Zip file sent. Screen shots & original HDR.
