Topaz AI Crashes when changing default sound
When processing a video with Topaz AI, changing the default sound settings consistently causes the application to crash. This issue is reproducible 100% of the time.
I am running Windows 11 (latest release 24H2) with all updates applied and have tested the problem using both an RTX 3080 and an RTX 5080. The crash occurs regardless of the video card in use.
Can you send the apps logs and a screen recording of this as well?
  1. To gather logs, please select Help > Logging > Get Logs for Support and attach the zip file to your reply.
  2. A screen recording of the behavior?
  • We recommend loom, it’s free and easy to use. Once your Loom recording is ready, you’ll be able to get a link with the video, please reply back with the link
  • Feel free to use any other preferred method and send the video file attached to your email replace. If the file is too large to attach, you can upload it here: Submit File to Dropbox
Feel free to email us at help@topazlabs.com if you prefer to share privately. Please include the link to this forum post.
