Topaz AI 3 running incredibly slow after upgrade
[I have a MacBook Pro with the highest specs for the 16in M3 MAXX model. V3 (the latest release) is running incredibly slow after the upgrade.
I am using latest update to Sonoma Mac OS - so everything else seems to work fine.
Please rectify with Mac OS as my work depends on being able to carry out noise reduction and other enhancements. Should this continue, I will be forced to move to another platform (unfortunately).
Regards and thanks ahead
Andrew
Please follow the instructions below to fix this issue:
Topaz Photo AI Freezes on Importing Image (Mac)
Let me know if it’s working after doing this and I’ll keep an eye out for your reply.
This worked for me for the same slowness problem ^^
