Topaz AI 2.2.1 eye distortion even at lowest NR settings
On certain bird photos, 2.2.1 distorts and discolors eyes. Previous versions did not do this. Mostly apparent on birds with yellow eyes such as Bald Eagles, Blue Herons, Common Goldeneyes.
Steps to reproduce issue:
  1. Load RAW file into Photoshop
  2. Run Topaz AI plugin
  3. Even on lowest setting it will distort/discolor.
@rjm-7227 Could you take a screenshot of the used settings for one of these pictures?
Would you mind sending me more information in order to get a better understanding of the problem you are having with this image? I would like to try and reproduce this image, in order to do so would you please send the following information:
  1. The original image file.
  2. The processed image.
Dropbox File Request
