Topaz AI’s latest release 1.3.3 creates a problem with handling Fufifilm RAW file (RAF). Unlike all previous versions a modified RAF file will not be properly saved in my Capture One (22 Pro) application. All modifications are totally lost and even the crop is returned incorrectly. However, it seems to work with JPG files.
How are you sending RAW (RAF) from Capture One? The ‘process with Topaz AI’ in the ‘edit with’ menu offers no option to send RAF files.
DNG is an option, but even that is TIFF in a DNG container and not real RAW sensor data like a DNG from a camera. In all the ‘edit with’ options the raw image is already demosaiced and a base profile/curve applied by CO.
Or the other way round: how are you loading RAF files in Topaz and saving as “modified RAF”? As far as I can tell you can only save as DNG (TIFF inside, no raw file) or JPEG/PNG/TIFF.
My normal workflow is (was): Editing Fuji RAF files in Capture One (often cropping). When done editing (menue: image - edit with …) the file in AI. After that saving back to C One (as a JPEG, obviously, not a RAF). From C One I did export the result then. That did work up to v1.3.2.
Now (v1.3.3) it saves back, however, no changes made in AI are retained (upscaling, sharpening, denoising …) . Even the crop seems to be transferred incorrectly, if at all (may be not always, I am not sure).
When using CO for export (to jpeg) I would advice sending to and saving from topaz in dng or tiff format. Doing so in jpeg and then export in jpeg would mean double lossy compression.
Regardless the chosen format it’s still strange of course that the saved result is not containing any of the enhancements like they used to…
Do you perchance use xmp sidecar files?
Thank you for advice. However, I havn’t changed anything during all the AI versions in my workflow. I do not use xmp sidecar files. Something has changed from v1.3.2 to v 1.3.3 that relates to my Fuji/CO/AI setup.
Yes, I am using NORTON Security Online antivirus. However, I doubt that that has any influence (how?), has it?
Correct, I am using the “Image >Edit with > Topaz Photo AI”. Means, I edit a Fuji RAF in CO and then transfer it (as a copy) into in Topaz AI, as described (as a JPEG).
As a matter of fact, Popaz Photo AI returns the JPEG correctly to CO. Hoewever, when exported as a JPEG from CO the changes made with AI are not saved. You can see this in the screenshot below. rigt side: JPEG saved from AI ti CO, left side: this same JPEG exported from CO into a folder. - B.T.W.: The bird is a Caspian Tern (in German Raubseeschwalbe). Quite rare here.
I always used the path IMAGE > EDIT WITH > Topaz Photo AI (than edit as a JPEG). That work perfectly until and including v1.3.2.
However, there is no “process” with Topaz Photo AI (see screenshot), unlike shown in the explanations in the suggested link . Did you really mean that?
Should/can I reinstall the plugin to get the missing entry “process with …”? And how?
