I went to update to Topaz Adjust AI 1.0.6 only to find that Topaz Adjust AI 1.0.5 has no uninstaller. As the email advised to uninstall the previous version I am wondering what to do next??
You don’t say what OS you are on but for windows delete all folders such as the Program, Program data, local app data etc.
If you use PS or LR delete the plugins and external editor presets and install the latest version.
Hi Don
Thanks for the advice, yes I am on Windows OS
Regards
Hi Don
Followed your advice and the new version installed and ran with no issues
Thanks
Regards
Jim
