Topaz 7.2.2 plugin for PS25.9.1 (Win 10) does not open. Stand alone works 100% .Automate in PS crashes Topaz
PC Win 10 Pro Upgraded to Topaz Gigapixel AI 7.2.2 . Plugin in PS has error message “Failed to open shared memory for mask channel” Standalone Topaz Gigapixel works fine. Uninstalled / Deleted previous installation of TPZ Gigapixel as recommended reinstalled and rebooted…problem is the same.
DxDiag.txt (142.6 KB)
Error message from within PS
OK I think I fixed the problem. The previous installed TPZ Giga plug-in files were not overwritten by the 7.2.2 upgraded installation in the Adobe PS plug-in folder. I copied and pasted the new upgraded files into the Adobe PS plugin folder and it seems to be working although it is a bit slow.
Hi Gerry!
Thank you for sharing your update!
I’m glad you were able to resolve.
I appreciate you sending your system profile.
Based on what you sent, your NVIDIA Quadro P5000 graphics card driver was last updated on 10/18/2023.
You may be able to go to NVIDIA Support and ask about updated your graphics card driver.
This may help with speed issues.
Please reach out again if you have other conflicts.
