Since the update to 3.5.1. multiple files are not processing. The videos start encoding but the preview freezes and no % progress is displayed or also freezes. Spent 3 hours with no progress. Have tried upscaling various video formats, apart from trivial Artemis upscaling of 360p, nothing has worked.
Previous versions all worked fine whether progressive, interlaced or smoothing. Have uninstalled and re-installed. Cannot try 3.5.0 as no access to a roll back (that would really help!).
My system is Windows 11, Pentium I7 (12th Generation) with NVIDIA RTX 3060 and 16 Gb RAM.
Similar issue on 3.5.1 when converting a frame rate, starts processing then stalls part way through and doesn’t complete, or completes with a corrupt file after a long delay.
Windows 10 Pro - Intel Xeon Gold, NVIDIA 4060 Ti and 128GB Ram.
solution: uninstall 3.5.1.
find 3.5.0 here and install it: Releases - Topaz Community
problem solved!
(just skip updating until topaz increments past 3.5.1)
We’ve seen a few reports like this one where users saw processing issues after updating to 3.5.2. It seems that some users will need to follow these steps to reset and reinstall version 3.5.4 of Video AI:
