Topaz 2.2.2 PhotoAI denoise function is generating rainbow artifact
Topaz 2.2.2 PhotoAI denoise function is generating rainbow artifact. This photo was shot at ISO 2200 and had a little noise but denoise was initially turned off. When I turned it on I see the artifacts. This is a picture of a bird and has a lot of fine feather detail.
Windows 10
Don;t forget to upload the photo.
Should I upload the raw file?
Not unless support asks.
  1. The original image file.
  2. The processed image.
Dropbox File Request
You can reach out to us on our Support Page for more direct communication at the following link:
Topaz Labs | Support Page
John, I’ve uploaded the .NEF file, the .TIF, and a screenshot of the PhotoAI denoise settings. Let me know if you need anything else. I don’t think I mentioned this earlier but I’m working from Lightroom and using the Edit In > Topaz Photo AI function.
Tom
Thanks for sending in those images. I was not able to reproduce these artifacts you were reporting, however I was making these edits with the most recent update.
To troubleshoot this issue I would like to try updating you to the most recent version release to see if this resolves the issue.
I reinstalled using your link. I’m still seeing the same result. Note that the Autopilot did not identify the image as needing denoise - only sharpening. The rainbow effect only shows up when I turn Denoise on with the toggle switch.
