“Themis” is causing a colour shift in blue/indigo (EBU primaries?)
- With two duplicate projects, one with, one without Themis, the Themis one has transformed some of the cobalt blue (saturated) hues into indigo, a little purple. The project is 1920x1080p50 into 4K50 with Apollo (6x) and Gaia HQ. It may be relevant that the source is Transfer Function “ITU-R BT.709” but with Colour Primaries “EBU Tech 3213” and YCbCr Matrix “ITU-R BT.601”, due to the 576i origin of the footage.
The correct result comes in the output file: *_apo8_ghq5.mov
The wrong result comes in the output file: *_thm2_apo8_ghq5.mov
- Available on request but I need to know if it’s relevant before releasing; this is only a data issue.
- Attached: logsForSupport.tar.gz
- See four screenshots
