Hi,
I am able to run a single video file, but when I start queuing up multiple input files. The status bar only show for the top two videos and they don’t move after 6 hours.
Commando
Hi,
Commando
Hi, just come back with an update. I’ve fixed the issue by setting the process number to 1 (default is 2). It seems it can’t process two videos simultaneously.
The default of the app should have been set to 1 for max processes, and when running the Starlight models locally, you will definitely want it set to 1; otherwise, your system will try to run both, and that splits resources out and will end in an error.
