The new Beta Erase feature is way, way, too slow. It is so slow that it is really not usable
The new Beta Erase feature is way, way, too slow. It is so slow that it is really not usable at this time.
Steps to reproduce issue:
  1. Step 1 Try and use the Beta tool “Erase”.
  2. Step 2
  3. Step 3
Well, without giving any details about your system/hardware I guess no one can tell much.
If you don’t have a good enough GPU, it will only use the CPU for the remove function, and that is very, very slow.
I have a GTX 1060 6Gb which sits idle during the remove process (I think 8Gb GPUs are currently set as a minimum requirement for GPU processing).
