The first one is a base image that was edited in part in Studio. The second one has a Jason Odell Abstract Painting texture applied in Texture Effects. In this plug-in, I was able to rotate the texture. My question is, is there a way to rotate a texture in the Texture Adjustment in Studio?
Jack, I think once you have a texture selected you press the edit button and the texture has a white border around it … if you go to the corner it is possible to rotate by moving the cursor.
