Test of 7.3 Beta
Hello,
thank you for adding me to the Beta testing
I am working in a MacBook which is 3 years old.
I do not See the new features like warp mode and so.
Is it a problem of my Mac or how can I find the switch to turn it on.
Greetings
Michael
Hi Michael,
Thank you for reaching out!
Usually the Beta tester program requires that you mention your hardware in your About Me section so that we can review your computer hardware to make sure it can run our newest builds.
Our most current version of the beta build requires at least 6GB of VRAM.
But your macbook at 3years old should still open the application. When you downloaded the beta, did you see the beta version in your Applications folder? The application looks very similar except it says “Beta” in the Gigapixel icon.
Does it show up like this? If not, you may need to reinstall the beta again.
Screenshot 2024-07-01 at 3.51.30 PM
Hello Esther.
Yes I use the Beta Version.
Where can I find the new tools.
All of this I know from the regular version.
Greetings
Michael
HI Michael,
There shouldn’t be any new features visible in the beta version.
Unless you click on Recovery, you’ll see the Quality &. Speed Mode but also there is a Regenerate button that’s new.
