System completely froze with 1.7Gb Mp4 file
  1. Attempted to process 1.7Gb Mp4 file that was originally a VHS conversion. Used Artemis MQ as the 1st Enhancement and Iris LQ v2 as the 2nd enhancement. Started the process on Saturday 3rd May and came in to find PC frozen this morning 6th May.
  2. PC is an i7 10th Gen 2.9Ghz, with 80Gb Ram and a Nvidia RTX 3070 GPU. Running Win 11.
  3. Your log files (Help > Logging > Get Logs for Support) - Log Files attached
    logsForSupport.zip (2.3 MB)
Open the Preferences Panel and change the following settings.
File>Preferences>Processing
  1. Ensure that your GPU is selected for the AI Processor
  2. Set the max memory to 80%
  3. Set max processes to 1
  4. Save the settings and close the panel.
  5. Re-run your clip through the process that you were trying.
If you run into an issue again, please send the updated logs for further review tp the support team at help@topazlabs.com or you can post them here if you want.
