Subject detection setting not copied to all images when applied using current settings to all
After loading a bunch of images I want to switch subject detection to none. I also set the noise reduction model and level. I copy the settings using ‘apply current setting to all’. The noise reduction parameters wil be copied to all other images. My subject setting is not.
Of course I could set that preference globally but normally the auto pilot does a decent job. But with these photos is does not work. I want to change the setting just for this job.
2023-08-24-12-27-33.tzlog (990.2 KB)
Steps to reproduce issue:
  1. Step 1
    Load the images
  2. Step 2
    Set the subject detection to none for the first image
  3. Step 3
Thanks for reaching out. For a single batch it would be best to switch the Autopilot subject detection to none, then switch it back when you’re done with the batch.
I made a task for my team to look into this feature to copy and paste the Subject Selection settings.
