It appears that one can no longer mask out part of the image when using Topaz Denoise. It is often important that an entire image does not receive noise reduction. In the past I was able to use this feature to block out areas or also to do multiple passes applying noise reduction at different levels to different parts of the image.
Not sure why this was removed or if it is bug in the current Mac release?
