I have been pleasantly using Studio and would like to know whether the addition of the Adjust AI is worthwhile. Are the two programs similar enough that adding Adjust would be redundant? I can’t, fully, tell from the product descriptions, they sound similar to me.
I find that Adjust AI works best on RAW files so if you use a trial, be sure to test it on yours. In the controls section it defaults to off. To get the AI, click on Standard or HDR. The HDR treatment can induce color shifts sometimes and even in the standard mode I often have to do some manual adjustment. Below is a picture of a Sony RAW picture vs what I could do in Adjust AI. I would like to see the AI part improve though.
