I loaded the upgrade and tried using the AI Clear trial. It worked okay but I got this weird message on the left side of the work area.
See attached.
Harry
See attached.
Harry
Try resetting the database. Help-> Reset Local Database
Thanks Don. I had done that to get AI Clear to work, which it did. I’ll give it another go today.
I’m still getting it on both computers. Doesn’t interfere with anything so I’m not too concerned.
