When I choose File → Save As → Save as types → Project Files (*.tsp)
everything seems to go OK (without any error messages)
but no new file will be created for the disc.
I have tried save to SSD and HDD but the result is same
I can save jpg, tif and png format but not project files.
You may need to wait for Support to respond, at first you should have received a email acknowledging that you have submitted a request.
If you didn’t receive that you will need to submit another request, if you did receive that just give them a nudge by replying to that request. Do not raise another request if you did receive acknowledgement.
On the issue of saving the project files just make sure that you have read/write permissions for that particular directory that you are saving the file to.
Note that I don’t have any issue on Windows 10 with using Project files and I haven’t seen any other reports.
Ticket Id #128562 Created October 07, 2017 22:42, and yes I have email “Request 128562 has been received by Topaz Labs!”
I’ve done two reminders to that ticket
I have read/write permissions, 100% sure
what about that
“As for the lost Project files make sure first that they are not saved to different locations on your PC as I have recently reported that the Save as only saves to the recently opened file location, not the last saved file location.” Project Files - #5 by AiDon - Product Technical Support - Topaz Discussion Forum
And yes, I have updated to Topaz Studio Ver: 1.4.3
Can you send me project file so I can test if I can open/resave that
The best option is to wait for Support to respond, if I look on the support site and they seem to have a large number of requests as they have posted the following:
“We’re still pushing through a large volume of support requests, so please be patient, and only submit your request one time. We’ll make sure everyone receives an answer!”
Update to Topaz Studio Ver: 1.4.4
same behaviour, cant save project files
I have found what is causing that error.
Those project files are actually ZIP files with TSP extension.
When you save project file Studio first save that file to TEMPORARY folder with ZIP extension and
then moves that ZIP file to selected directory and change extension to TSP.
When I open file “topaz-test.jpg”, make adjustment and try to save project file this is what happen.
Studio try to save ZIP file to TEMPORARY directory
in my PC TEMPORARY directory is "c:\temp" (because that’s the way I like it)
now error happens: Studio try to create file C:\temptopaz-test-Edit.zip
it does not use TEMPORARY folder, it use TEMPORARY folders PARENT directory
in my case that parent directory is C:\ where normal user can’t save files
My test case 1.
Run Studio with administrator access level
Now I can save project files because Studio can create file C:\temptopaz-test-Edit.zip
My test case 2.
Chance TEMPORARY folder to c:\temp\test\ and run Studio with normal user access level
Now I can save project files because Studio can create file C:\temp\topaz-test-Edit.zip
Topaz Labs can easily repeat the problem
change you TEMP environment variable to point "C:\temp" or “C:\temp” (does not matter)
I am the developer on project files, so feel free to message me at any time, or tag me directly in posts.
I have added this case to my task list. I believe it is easy to fix. I won’t give an exact date right now, this bug fix is competing against all the other possible fixes I can make, and I need to prioritize the most prescient bugs first.
I don’t regularly check the forums and respond on here every day because it can become very time consuming and that time is better spent coding. However, I am working on project file bugs and edge cases in the near future, and this item has been added.
Thanks again for your feedback. I know it takes time and consideration to spend the time reverse engineering how the project files work and provide us with a well written report like you did. I appreciate you helping us test and keep up the great work.
