I have Studio 2 as a plugin to Affinity photo. Everything in Studio 2 works with the exception of Looks. Nothing shows
When I use Studio 2 as a standalone, looks appear.
I just tried using Studio 2 being called from Affinity Photo and it worked correctly. Looks show up when I click the “Add Looks” button and I applied one and returned to Affinity with the correct look applied. You might uninstall and re-install Studio 2. I’m on a Windows 10 machine with the 2004 update installed.
