Just download the installer from the Download page on the Topaz Labs website and reinstall, there is no need to uninstall as the installer will do that for you.
That sounds like you have other issues with your PC if the uninstaller runs like that or you had Studio 2 running in the background while you tried to uninstall. For me it only takes a second as it just deletes the folder.
