Please add guide lines to Tilt and Shift. Current implementation is unusable. Thanks.
It’s certainly not easy to use the tilt shift option without guide lines.
In the circular blur it seems a little strange to me that with the transition set to 0, the blur extends inside of the guide line. I would have expected the guide line to designate where the blur starts. I guess I’ll get used to it though.
