I am using Studio 2 to edit the file from LR and I want to use the Sharpen AI plug-in under the filters tab within Studio 2. When the plug-in comes up, it says I am using version 1.4.6 and need to update. I select update and it takes me through a download process. When I go to the DMG to open it I then proceed to update the Sharpen AI standalone application and not the plug-in.
When I open the Topaz sharpen AI app is shows I am using the most updated version 2.1.3. However, when I go back into Studio 2 | open a file for edit | Then use the Sharpen AI plugin under filters; it shows I am still using the older version 1.4.6 and need to update again. Seems I am in a never ending loop. How do I get the plug-ins updated with the standalone versions or at least updated to what they should be?
Best regards, Michael
