It gets stuck while removing noise at about 80% of the process
It’s possible you’re missing model files. Please rerun the installer.
If that doesn’t work, submit a support ticket at support.topazlabs.com using the beacon at the bottom right corner of the page. They’ll be able to help troubleshoot using specific info about your computer and images.
