Stuck on Loading Images
When opening the program and importing photos, the program is stuck on ‘loading images’ and does not load. This happened with one photo or multiple. It’s just stuck on this screen and nothing can be done.
Steps to reproduce issue:
  1. Force close program
  2. Repopen program
  3. Imported photos
Topaz Photo AI 7.0.1
Macbook Pro 2023 -Sonoma 14.2.1 (23C71)
Topaz Labs Download Page
