Stretch to Fit / Seperate H/V AR
Hi there.
Since I work with sub-par footage often enough, I would like to see an option to correct a source video`s horizontal/vertical AR seperately, respectively an option to stretch the output to the width/height pixel values I entered.
The required technology is already in the software, it only needs another option/entry field.
Thank you.
That is a good idea :slight_smile: Make sure you vote for your idea!
Agree.
