I would not go with TPAI for Raw denoise at the moment, bc. it does cut off highlights and you did not buy a 8K camera with an BSI sensor for getting lower dynamic range.
You could denoise the image after you did edit it with the raw converter of your choice.
Ok, the corrections look more or less the same with 2.07 or then later versions. I have checked all newer versions after 2.07 – always the same. But it might be a speed optimizing process related to the remove brush – something I can life easily without… I don’t think that average exposure is possible within the camera. But on the whole, the IQ is quite impressive.
I use PhotoLab 7 for RAW denoising because it is the most reliable and has a nice fine detail resloution (good for enlarging with PhootAI) (if you use Deep Prime XD) and no its not the same as PureRaw.
But it also has its problems like changing the white balance and pattern generation at high values.
It works best at 30% and with the legacy color space.
If you come to PhotoAI as a tiff after Capture One, it is recommended to set the denoising in C1 to
Thanks for the values. Since I am using/tesing a lot of different gear - including PhaseOne backs – I stick with C1. PL7 is not really my taste when it comes to usability - but the demosaicing is nice as well as the DeepPrime algorithm.
