The bug / behavior you have encountered
a) hit Reder 10s
b) wait process finished
c) click PLAY:- rendering starts (?) and not stops anymore until finish of video (!)
- video preview stop after 1 sec
- only way to stop rendering is change a random params on right UI column
Your system profile
TVAI 6.1.3 / Windows 11 / i9 14900k / RTX 4070 Ti 12GB -
Your log files (Help > Logging > Get Logs for Support)
No need. Others have same issue -
Any screenshots as necessary
The team is actively looking into this issue at this time.
- The same issue for me after updating to version 6.1.3. I choose to render a 2 second (also a 5 second) preview. After rendering has completed & I choose “play” to view the preview, I see approximately a 1 second preview, after which the green bar to the bottom indicates continual further 2 second previews are being played (the same happens with 5 second preview renders), for the entirety of the video.
After managing to re-install version 6.1.2, the issue has gone. Thank you Topazlabs. I wait for your fix. - System TVA 6.1.3 / Windows 10 Pro - Version 10.0.19045 - 64 bit / Mobo B550 Aorus Pro / Ryzen 9 5900x / RTX 3060 12GB
- Log file attached logsForSupport.zip (594.4 KB)
