Stopping and not making pictures better
I don’t get it when I updated to the 7.0 version the first few pictures I did turned out amazing and so much better. Now it isn’t doing better but making them worse or nothing at all. I compare the before and after pictures saved with different names and there is no difference in quality. I know I can make them bigger but don’t need a 60MB image just a better image that better quality. I can’t believe the difference with the first pictures compared to what I am getting now. They suck. what is going on with this program. I changed nothing in the settings kept everything the same and pictures are turning out worse or nothing but a bigger size.
If you are willing to share some of your images, we may be able to decipher why you aren’t getting the processed image you had hope for. Without additional information, it will be hard to determine the cause of your conflict.
