Hello,
I just downloaded the 7 GB starlight precise model but cannot export anything, as the option is geeyed out.
How can I resolve this?
Thanks!
Hello,
Thanks!
Can you send me a screenshot of what you are seeing and the logs from the app to help@topazlabs.com and I can check with the devs on what is going on here.
Have you tried restarting the app? Or just select another model first, then select SLP. I saw the same thing when I updated my test platform and the above fixed it.
Yes I did try that, same thing each time I open Topaz Video…
Thanks, are you on a Mac system or Windows? If you can send me the logs, I can share those with the team to look into this. We are investigating some Mac-specific situations with regard to SL Precise 2.5 and the local processing being greyed out. I want to make sure they have as much information as possible to get this resolved quickly.
