Starlight Precise 2.6 (local) artifacts issue
Tried to use Starlight 2.6 local on Mortal Kombat Trailer and it is leaving strange vertical lines across scenes. I have attached the before and after for comparison. This issue was not observed with Starlight Sharp.
Can you share the original source file?
Submit File to Dropbox
I sent you a DM. Thank you for your time.
I was able to replicate in some areas of the video, sharing to the devs for review.
Thanks again for your help.
