Starlight Precise 2.6, auto resume after failure/stop no longer works 1.7.0
Previous versions using starlight 2.5 if the application was shut down and restarted the applicaiton would automatically resume from where it left off, this no longer works, it just says “downloading model” but looking at taskmanager you can tell nothing is going on, no bandwidth usage, no cpu usage, i let it stay there for 30 minutes nothing, restarted application same thing happened, only way to re-trigger is to remove the media and then add it again, but when you do that your already processed data that was saved is now deleted so essentially you have to start over losing hours of progress.
  1. please fix this
  2. best case scenario give us the ability to PAUSE startlight render.
The team is looking into reports of issues with the new 2.6 model at this time. To assist, can you send your logs in for review? help@topazlabs.com
They have been working on various aspects of trying to help with issues after the app crashes or is closed and a file is trying to resume when launched again, however, the diffusion-based Starlight models run a different process that is a bit tricky, this is why there is not currently a pause option for them.
