If something takes a long time, then that’s just the way it is. But if something takes a long time because it isn’t fully utilizing the PC’s resources, that’s a different matter. And if something causes jittering because it’s not using enough VRAM even though more VRAM is available, that’s also something that can legitimately be pointed out. And yes, if something runs slower than before (at the same quality), that would be difficult to understand, assuming that’s actually the case…I haven’t been able to observe that myself (yet?).
I think that Starlight precise in 1.61 is slower than 1.60. The estimated time is no use, however, so I am not 100% sure as I am not doing exactly the same clips as I did before 1.60. I did try reverting to 1.60 but it made no difference. So it is slower after the update? I had wondered if any one else thought so until now.
I have become a big fanboy of topaz and starlight precise 2.5 to be honest.
I tried mini vs starlight precise 2.5 locally. Mini is decent but IMHO precise is better even for horrible footage. It is incredible, i got some super old family footage from the 60s-80s to 4k. First Starlight 2.5 4x upscale and then proteus with mininal settings upscaling to 4k. The original footage was 320 240. I found that with interlaced videos, running starlight directly is better than than using deinterlacers like dionne which made the footage very AI Plastic. In my view Starlight Precise is a big step up from mini in terms of quality, I did see some youtube videos testing this but I think this was July 2025 Starlight vs Mini but on my own footage I found it to be remarkable, so well done Topaz Team.
Furthermore mini is so slow locally 5 minutes took 12 hours on a 4090
btw I found that 5090 isn’t at all faster than a 4090 for starlight precise
So one thing I would ask you guys to work on is somehow make it a bit faster, also super long renders like 2-3 days are prone to crash so i basically leave the node running without touching it whatsoever. Finally you should give some advice on whether we should max the VRAM to 100% or 90%, some user reports say 90% is better. I found that it is true when I allow 2 parallel processes and i run 1 starlight and 1 non starlight that 90% on a 4090 with 32gb ram is better. On machines with 5090 and 64GB RAM there seems to be no difference.
Last question will the blackwell pro 6000 96gb run faster starlight?
could not agree more. Starlight 2.5 is just incredibly. I tinkered with ComfyUI and Seedrv and nowhere near the quality produced by Starlight
The model is very heavy and slow to process, but that is something the research team is working on improving as they can. This will take time though.
There are a lot of variables and we have seen that some users systems run better at various levels of max memory due to their configurations and other software that is running. What works for some does not work for others on the same hardware, as each users workflow is different.
We have not seen enough testing to compare the Blackwell pro 6000 to standard consumer cards like the 5090. At this time though the 5090 is a more viable card for most users.
Hi Kyle,
Topaz’s April release introduced NeuroStream VRAM-compression tech (cited as up to ~95% memory reduction), but the announcements framed it around AMD GPU support. On my NVIDIA fleet (RTX 4090s and a 5090) running Starlight Precise 2.5 locally, I’m seeing a consistent ~11GB spill into shared system memory on every card — including the 5090 with 18GB of dedicated VRAM still free — which tanks throughput.
Is NeuroStream (or any equivalent VRAM optimization) active for NVIDIA Starlight Precise 2.5 local rendering? If not, is it on the roadmap for NVIDIA — and any rough timing? That’s the piece that would directly address the spill I’m hitting.
thanks so much
All of the Starlight models run via the Neurostream setup within the app now. What release are you referring to when you mention the 95% memory reduction? I want to check with the dev and research team on those details to get clarity.
When processing 37 minutes of Full HD footage into 4K over the course of 3 days and 16 hours, the processing rate is 0.21 frames per second. This is normal.
On different systems I have access to (Mac), I get between 4.7s and 18.4s per frame. This is the speed we’re getting with Starlight Precise 2.5/2.6. Of course I wish it could be faster but the quality is extraordinary in comparison with previous models, so I accept this.
