Using Starlight Mini, I select export to cloud. It the brings up “21 minutes 150 Tokens”, but I can only select 6 minutes chunks of video. So is it 150 tokens for 6 minutes or 150 tokens for 21 minutes?
The cloud processing workflow for the Starlight models is limited to a 9000 frame length clip per job. Depending on your frame rate that could range from 5 minutes to 6 minutes and there will be a screen with a blue box to select what section of the video is going to be processed.
On the next screen after confirming that selection range, the cost per cloud credits will be displayed for confirmation before the file is uploaded and processed.
You can review more on the docs page about the full cloud processing workflow and a chart that helps breakdown the cloud costs based on model being used, resolutions and frame rates of the source and output.
