Starlight Mini locks in to frame rate selection
Hello, I noticed when Starlight mini selected it locks in whatever frame rate we selected on the “Frame Interpolation” section and doesn’t allow update. It generates videos based on that frame rate.
If it’s able to adopt we’ll need to be able to select after choosing “Starlight Mini” if it’s not sensitive it could be defaulted to whatever supported.
Thank you
Hello,
I wasn’t able to reproduce this, could you share a screen recording of the behavior?
  • We recommend loom, it’s free and easy to use. Once your Loom recording is ready, you’ll be able to get a link with the video, please reply back with the link
  • Feel free to use any other preferred method and send the video file attached to your email replace. If the file is too large to attach, you can upload it here: Submit File to Dropbox
Thanks!
