Starlight mini is not loading
Starlight mini is not loading any more locally and gives ERROR. NVidia Geforce RTX 350 (8 GB)
Can you share your logs for review into this matter? help@topazlabs.com
(attachments)
logsForSupport.zip (414 KB)
Looking at the logs, it looks like the model was not download correctly in the backend when updating.
Two things to try here:
Open the Model Manager, and remove the current Starlight Mini model.
Then click to download it again to see if that gets a clean copy.
If not, do a full uninstall of the app and clean download and installation, selecting to clear all the models and files when prompted. Would recommend rolling back to 1.6.1 as well as there are a few bug issues being worked out in 1.7.0.
Topaz Video | 1.6.1 | - Win
Thanks, Kyle,
It took me a while to find the Model Manager (under File), however, uninstalling and re-installing Starlight Mini did not yield any success in running it without stopping with ERROR.
The installation of Topaz Video 1.6.1. ended in the same way as did the update to 1.7.0 which I had made a while ago, i.e. in the warning
Topaz Video Setup
Neuroserver component install did not finish: neuroserver-deps.tar.xz. First issue: no candidate URL reachable. Topaz Video will use the built-in backend. To retry, run the Topaz Video installer again and choose Repair.
Repair did not work either.
Trying to run Starlight Mini with the incomplete installation does not work. It cannot even be klicked for running it locally.
The same with the attempt to update to 1.7.0 again. The Model Manager doesn’t contain any Neuroserver Modles any more.
Please find attached the new logs.
Kind regards
Franz
(attachments)
logsForSupport.zip (552 KB)
TopazLabs documentation for Starlight Mini shows a minimum GPU VRAM requirement of 10GB (Starlight Mini | Topaz Video). Your RTX 3050 GPU only has 8GB of VRAM. I’m not sure you should ever expect Starlight Mini to load, let alone function, when your hardware doesn’t meet the minimum requirements for the model.
Starlight Mini has worked for many months now, although being rather slow, e.g., clips of 3 minutes would take about 24 hours. The requirement originally was 8 GB. Shall I go back to an even earlier version of Topaz Video?
The URL issue is being worked on right now by the devs for a resolution. The recommendation is that Starlight Mini has 10 GB of VRAM available for use or higher, however, it can run with 8 GB as that was the original limitation of the model. As the model develops that might change and there are some 8 GB cards that can not run the model due to older architecture (Tesla series, etc.).
Thank you, Kyle. So I wait and enjoy what I have already done. And in urgent cases I invest some money in the cloud version.
