This is normal speed?
Intel i9 285K
Asus 5070TI
RAM 64GB
What exact are you doing?
Upscaling and enhancing dvds to full hd with Starlight mini I get with my Rtx 5060ti 16GB 0,3 - 0,4 fps. So your timing might be right, too.
We’ll need a bit more info. Can you share the app’s logs?
To gather logs, please open Video AI and select Help > Logging > Get Logs for Support and attach the zip file to your reply.
excatly input and output resolution would be helpful when it comes to speed. If you have 540p source and doing 2x to 1080p its a bit slow, you should get about 0.4-0.5 fps with a 5070Ti, if you do 3x upscale, then 0.3fps is fast for this card
