The bug / behavior you have encountered
The edge hiding software Method (Full-Frame or Auto Crop) is always on. Cannot turn it off or disable it even when it is causing problems.
Your system profile
Your log files (Help > Logging > Get Logs for Support)
Any screenshots as necessary
Can you upload or share the logs and a screenshot showing what you are referring to? I am trying to picture the issue and sort out how to replicate it for the devs to look into.
In order to troubleshoot this, I will need your logs and your full system profile.
Hello,
I encounter issues when using Topaz Stabilize because it also treats the resulting edge jitter with Full-Frame Method or Auto-Crop Method and it can’t be turned off. (See attached) This problem example shows a fuzzy cloud in the letterbox area that fluctuates and bounces around. I have to find work-arounds to fix these problems that crop up such as using the Topaz Crop feature or switching between Methods. I don’t need or want edge treatment to deal with black spaces around the edges at this stage of my work. I fix that when matching to the other shots later on using other software. It would be nice if I could switch “Stabilize Method” off.
Thanks,
Tom
Are you able to share the file with us that you are seeing this happen in? The team wants to use it for some testing.
Kyle,
In reply to your request, I sent 4 files on Dropbox, the requested video clip, two screen captures and a txt note.
80 Days Balloon sky-3 color corrected.mov
Note-80 Days Balloon sky-3 color corrected.txt
Thanks,
Tom
