Stabilization Full Frame produces tile effect on macOS 27.2 (M5 Pro) - Topaz Video 1.7.1
Hello,
We have the same issue reported in this thread: Stab is producing a "tile effect" after updating to MacOS 27
Since updating to macOS 27, Stabilization in **Full Frame** mode produces a tiling / “tile effect” in the output. **Auto-Crop** mode works correctly.
**System details:**
- Mac with Apple M5 Pro, 24 GB RAM
- macOS 27.2 (the issue was already present on 27.0.x and the 27.2 update did not fix it)
- Topaz Video 1.7.1 (also tested 1.6.1 and 1.5.0 with the same result)
- Model: Stabilization ref-2, Full Frame
- Source: Canon H.264 1080p 50 fps MP4
We use Full Frame stabilization professionally for event videos, so this is blocking part of our workflow. I can send logs and a sample clip to help@topazlabs.com if needed.
Is there any ETA for the patch mentioned in the other thread, and will it include a fix for this?
Thanks!
A post was merged into an existing topic: Stab is producing a “tile effect” after updating to MacOS 27
