Split view is very shaky
    split view is very shaky
  2. Your system profile
    TVAI 6.1.3 / Windows 11 / i9 14900k / RTX 4070 Ti 12GB
    No need. Others have same issue
Can you elaborate or share a screenshot/recording of what you are referring to with shaky?
The team is looking into some issues where the video is not smooth when moving the split view divider back and forth when shifting between the original and enhanced video previews.
Simple way to reproduce the problem:
Take a video, transcode it via ffmpeg to h265.
Then you can use GitHub - pixop/video-compare: Split screen video comparison tool using FFmpeg and SDL2. (it’s a free super tool I use from years)
This video comparing way is perfect.
Is your “split view” supposed to work like “video-compare” ?
Your solution “dances/shakes” when you move left righet the vertical line, video-compare is stable instead when you move the vertical line.
Thanks for your patience.
