Speed Ramping
If I have say a 10 second clip and am only wanting a 2 second part of that clip with slow motion applied, I have to process the entire clip in the lowest frame rate interpolation method. I can process only the portion that I want slow motion applied to but then it’s nearly impossible to smoothly add that section into the original clip.
Thats what Davinci Resolve etc are for.
Yea I use Premiere but whatever NLE used is irrelevant. It is still a major headache trying to insert a portion of a clip seamlessly with the original. In Topaz, just like how you can trim a clip, it’d be nice to also select which portion of a clip you want slow motion applied to. That way you export the entire clip but isn’t entirely slowed down.
