Sound not syncing correct when using Starlight Mini
  1. I have used Starlight Mini for a very old MP4 file and the result was very good, but the sound is slightly moved so it’s not syncing exactly with the movie. Settings are as set by the program.
  2. System is: Windows 11 Home 24H2, Intel Core Ultra 7 265KF, 96 GB RAM, NVIDIA TUF-RTX4070TIS with 16 GB RAM C: 2 TB (1,26 TB free) (SSD M2), data disk 4 TB (695 GB free)
  3. Log file:
    logsForSupport.zip (5.0 MB)
The team is working on several issues in regards to Starlight Mini and they should have a patch release in the near future.
I will send them your logs for review into this issue as well.
