I am using Photo AI 3.0.4
As you can see with the attached photo, most of the topaz adjusted image looks much better than the original, except that for the non sharp-non focus number on the T-shirt: one ca easily read 426, but no number can be read on the treated image. Also on that image, the face of the man running looks much distorted on the treated image (much more than on the original), Best regards, AJP
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
Hi John,
I am absolutely sorry, and angry against myself : seems I updated / replaced my original with the Topaz modified version. I can’t find a copy of that original.
I guess sending you the Topaz adjusted file alone won’t help you much.
When I get a new similar example, I will dropbox it to you and let you know.
Best regards,
AJP
Alain J. Perseguers
TĂ©l. : +41 26 436 43 55
Mobile : +41 79 202 10 20
E-mail : alain@perseguers.ch
Adresse : Route des Cerisiers 5
1723 Marly, Suisse
Hi John,
Seems I found a copy of my original file, I juste sent that original and Topaz Photo AI V 3.1 result on it to your drop box.
Here is a copy of the panel:
Best regards
Alain J. Perseguers
1723 Marly, Suisse
