PHoto AI 1.4.2
I can’t spend 10 minutes per image waiting for Photo AI. I went to sleep.
@penrand Thanks for reaching out.
Please send me your system information following the instructions in the “Find your system profile” link from this site: System Requirements | Topaz Photo AI
The site has both Windows and Mac options. I want to check if your computer hardware is up to date.
Thanks for sending that. Manually select the GPU to use for processing. Go to the Topaz Photo AI Menu option > Preferences > General menu > AI Processor > AMD Radeon.
Hopefully this will improve the performance.
That helped, Thank you!
