Slowmo doesn't work
slowmo doesn’t work
Please explain with detail.
Since you suggested it does not work, I just tried Apollo 8 with a slow motion factor of 2X, and it did work.
Any one from Topaz will probably do the same thing and get the same working result.
Ok ,I’m getting error. The model is downloading after that nothing.
I can upscale and do everything ,the freme interpolation if it’s on for some risson nothing happens.
Thanks
I cannot think of why it’s doing that for you. Go to the Topaz main site. Click the little chat bubble in the bottom right corner to email support. They’re really good about getting you the unique help you need.
They will ask you to try and run the interpolation model, and then get the log and send it to them. You can find where the logs are kept from in the help menu of TVAI.
