I’m having the same issues on a Windows system. Subject selection/refinement lagging to the extreme. Practically unusable!
Asus Pro Art system
Processor 13th Gen Intel(R) Core™ i9-13980HX 2.20 GHz
Installed RAM 64.0 GB (63.6 GB usable)
System type 64-bit operating system, x64-based processor
NVIDEA GeForce RTX 4070
2TB SSD
Please send me your full system profile information as this will have more information about your GPU drivers that might help troubleshoot why you are having this problem:
Thanks for your reply and I apologise for my delay in replying, but I saw that there was an update, so I wanted to download it and try it before replying to you. While the update has appeared to improve the problem slightly it still isn’t as good as it was.
I have uploaded my full system info via your dropbox link today.
Helli John, I checked out the intel driver update site and it recommends against updating the driver through them and to do any updates through ASUS. Screenshot attached below if it works?
According to ASUS my system is up to date but I contacted the ASUS customer support and they reiterated what the intel site states ‘do not update from the Intel site’ as it can affect the function of my system. They also checked that my system is up to date with all required updates being installed.
I never had this problem prior to doing a Photo AI update and since doing the last update it appears to be a little better but only marginally?
Thanks for sending in that information. Let’s try adjusting your AI Processor to see if it makes the application more stable while running on your machine. Please open Topaz Photo AI and go to Preferences > General and set your AI Processor to CPU. Run some test and tell me how that goes for you.
I’ve tried it on each of the different settings and none of them seem to make any difference under the AI processor section. When trying to add a mask in the sharpen module there is roughly a 3 second delay on every stroke that you draw. I am also up to version 3.0.2 now after completing another update today.
When I want to adjust the mask with a brush, it does follow my mouse very slow and freezes a lot. It is actually not usable at all. How to deal with this?
With the new Update i experienced that sometimes the Brush tool, resets the size of the tool and sometimes the value of “30” is like a tip of a pencil and sometimes like i would use a cup or a spraycan… so it is not consistent unlike before.
When using the Paint/Erase tool for the selection mask for Sharpen or Denoise, the app will crash if the pointer of your cursor touches the edge/goes outside your screen at all. This can be very frustrating when trying to do precision alteration especially.
The circle can touch the edge, even a large portion of the circle if the masking tool brush size has been increased. The middle point, the cursor itself seems to be the trigger.
Exporting DNG from LRC to TAI. Sorry to say still same issue regarding lagging of brush on adding/removing parts of subject and that the movement of the brush is not smooth. Superpixel and objection selection worls fine. Have no issues in cursor movement in any other production eg Photoshop or Lightroom Classic. All drivers are up-to-date. Keep being told its being looked at but no time line as to when will be fixed.
Steps to reproduce issue:
Export copy of DNG from LRC to TAI - edit as a copy BUT happened with 3.0.1 when default was to overwrite
Let TAI analayze image
In sharpen layer click on 4 horizonatla lines to open layer
Select “selection” and “regular”
5 Sluggish, lagging red circle
If Topaz Photo AI selects subject areas in a photo that I don’t want sharpened, or missing areas that I do want sharpened, I manually fix the subject area. Quite often, Topaz will crash, forcing a computer restart while painting or clearing the subject area. This happens multiple times each session. I use Topaz Photo AI as a plugin with Lightroom.
Whenever I begin painting Red for remove…
two things I worry about. 1) Will I hit the edge of the image. 2) Will I let go of the mouse button.
If either event happens… if I’m even one or two pixels over the imagined border (I say imagined) because its a little farther than the actual border. What am I talking about.
The system begins processing.
If I let go of the mouse-button the same thing happens.
Instead. Why not let me finish painting what I want in the image first. Why does it have to go into ‘Processing-Mode’?
I know it would like to tell me… ‘Oh your image is over 2000 pixels’ or what-not. If that’s the case. Or it’s calculating the size of the box. But can you wait to do this ‘Processing’. Everytime I hit a ‘Edge-Wall’, or change-mouse-button. I have to ‘WAIT… WAIT’ and it takes so LONG!.
The process could be speed up if I didn’t have to wait for each ‘Processing’ function, until I tell it to do so.
Edit: This post was merged into here. I question whether the painting function acts the same for ‘Remove’ as it does for ‘Sharpen’. This above topic started on ‘Shapen’ or ‘Denoise’. Perhaps you can let me know.
terribly slow and not precise function
2.For erasing part of a mask, the brush size that can be set is not visible on the screen (there’s only a cross cursor), it makes the editing quite impossible. When using the brush, the results are unpredictable. And the brush size should be adjustable continuously, not in rough steps.
The last version 3.0.4 is a bit quicker than the formers, but it’s still annoying to wait so long for editing a photo. The workflow is heavily affected by this, increasing the editing costs, also for simple adjustments.
brushes in sharpeing very slow not accurate
