The benchmark numbers were unrealistic:
Input 720p - Output 1080p
Every mode ~18-25fps
Never seen such large differences from what I actually see (~9fps). My only guess is that TVAI treats these videos very differently in the background/processing.
Any programmer suggestions/info would help, thanks,
AC
The point of my suggestion was to compare your system to another similar one to see if your performance level is within the expected range. If it is, then your processing speed is not slower than expected.
FYI the benchmark and real world speeds are not usually the same, but the benchmark is a good tool for establishing a baseline performance level. Someone with double the benchmark speed than you will still get double the real world speed.
The benchmark tool only runs the AI models and does not export any videos or write files to the disk, so that could be the cause of the difference in performance results between the benchmark and a real export. Overall though, 9fps could be expected performance for the 3080 depending on the filters selected in the app and the codec used for export.
Could you share your settings to get a better idea of what numbers you should be seeing?
